  • February 22, 2020, 07:36:33 AM
Author Topic: psu Cable Sleeving Only one question one unanswered  (Read 5794 times)
kadimkris
« on: November 11, 2008, 01:34:56 AM »
i have read lots of Cable Sleeving guides and i have only one  question to be answered. how do you put the pins back in all the connectors ??? all the guides go in to detail  about sleeving and removing the connectors. then they say just put the wires back in and your done. well how is it done i dont want to make my psu unusable if you know what i mean.
Thanks for your time
Kadimkris
chase!
  • The Internet!
Re: psu Cable Sleeving Only one question one unanswered
« Reply #1 on: November 11, 2008, 04:06:15 AM »
On the pins they have little wings that you bend in when you take them out, before you put them back in the connectors you have to bend the wings back out. Once you take them out, you'll see exactly what I mean.
« Reply #2 on: November 11, 2008, 12:31:45 PM »
I also highly recomend getting a pin remover for molex connections. It makes it so much easier.
kadimkris
« Reply #3 on: November 12, 2008, 12:14:19 AM »
ok so i have a pin out of a fan's molex and still dont under stand about the tabs. if there out when i push it  back in the molex they close again. is there a tool to pull them out when you push them back in the molex. a detailed walk thought or info on putting this things back in the molex would be greatly appreciated.
thanks kadimkris
« Reply #4 on: November 12, 2008, 08:29:45 AM »
No, you kind of have to hope that they stay at least partially out, I don't know of any secret.
Page created in 0.068 seconds with 34 queries.
