  • June 02, 2020, 02:42:43 PM
Author Topic: Temp readings  (Read 7757 times)
Scorpion0308
Temp readings
« on: September 12, 2008, 09:57:37 PM »
Does anything in the picture I attached seem a little off to anybody else? Do I have a bad PSU? BTW I just downloaded "SpeedFan", opened the application and seen those voltages. Do I need to set anything up or are these temps accurate?
    • The Site Of Doom
Re: Temp readings
« Reply #1 on: September 12, 2008, 10:16:41 PM »
Well, the +12v, -12v and -5v voltages scare me, but I've gotten odd voltage issues with Speed Fan in the past, so it seems more like incomplete compatability on Speed Fans part for your boards sensors.
Generally I just check my voltages in the BIOS every other reboot or so, then I know those numbers are right.
Scorpion0308
Re: Temp readings
« Reply #2 on: September 13, 2008, 12:04:57 AM »
Ok, I'll just take a peak in there. Thanks
Page created in 0.056 seconds with 33 queries.
