  • December 16, 2018, 05:35:40 AM
Pages: 1 ... 3 4 [5]   Go Down
Author Topic: [Scratch Build] - Anima Mundi Redux  (Read 29598 times)
endscape
Re: [Scratch Build] - Anima Mundi Redux
« Reply #40 on: February 08, 2009, 07:37:57 AM »
wow, at least the hospital is over (for now?)
(i suddenly feel alot better)
If I make it until tomorrow at noon I will have had a whole week without going to the hospital.  That would be the first week in about a month and a half.
endscape
« Reply #41 on: March 22, 2009, 06:15:35 PM »
RaDragon
  • Tee hee hee.
    • RaDragon.com
« Reply #42 on: March 23, 2009, 02:04:15 PM »
the paintjob looks spotless from here!
endscape
« Reply #43 on: March 29, 2009, 03:23:35 AM »
Thanks!  It needs a little touching up, but otherwise it turned out pretty well.
Tried to get a picture of the finish, but I couldn't get a decent shot.  And this thing is a dust MAGNET.
« Reply #44 on: March 29, 2009, 10:12:19 AM »
It looks great.  I've been following this project from the begining.  I enjoy other's projects.  Makes me want to finish some of the projects I've started and never finished.  Keep it up!
endscape
« Reply #45 on: March 30, 2009, 02:23:29 AM »
Thanks!
So I'm lighting up the feet a little bit.  Well...a lot.  But that's besides the point.  Turns out I used the wrong resistor for my LED circle on the bottom, so its about 1/4 as bright as it should be.  I'm hacking it up tomorrow to fix that and augmenting it with some lighting in the feet.
Here's some proper photos.  I'm not happy with the edge finish on the top panel, so I'm going to have to go to town on it and try to get some of the deeper scratches out of it.  I'll probably repaint it after I'm done.
My awesome photography setup!  I need to grab the other work light to actually balance the light, but I'm not that picky at this point.
JYP_666
  • Console & Software modder
« Reply #46 on: April 01, 2009, 04:40:06 PM »
WOW! Now that's a mod! I could only dream of being able to do something like this! Keep up the good work, oh, and the hex-key/alan-key screws you used, are they skateboard screws? Its just that they look very similar to the ones that are in my skateboard ha.
B.T.W. My first post! Have been browsing this site for a while, decided to join since there is a lot of interesting mods on here.
Current mod's: NONE :( (Yet)
Finished Mods:
Slim Ps2 Fan Usb for no overheating
Slim Ps2 Exploit (A.R MAX Vers.)
FAT Ps2 Exploit (Independence Day)
Pages: 1 ... 3 4 [5]   Go Up
Page created in 0.062 seconds with 19 queries.
