  • June 23, 2018, 03:04:51 AM
Pages: 1 [2] 3 4 5   Go Down
Author Topic: [Scratch Build] - Anima Mundi Redux  (Read 29123 times)
endscape
Re: [Scratch Build] - Anima Mundi Redux
« Reply #10 on: September 14, 2008, 05:46:25 AM »
Someone on another forum asked how much this bugger weighs, so I piled all the parts that will be in the final build and weighed it.  At the moment it clocks in at 24.5 pounds.
On Monday I'm ordering a whole whack of stuff to finish off the project:
A Liang DDC Pump with built in reservoir
Two Vandal resistant white ringed switches
Three white Coolermaster LED fans
Four 120MM black wire fan grills
Four straight G1/4 compression fittings
Two 90 degree G1/4 compression fittings
And two sheets of copper, two sheets of brass, and two sheets of aluminum  ;)
endscape
« Reply #11 on: September 16, 2008, 08:05:02 PM »
Minor update:
Rebuilt the hard drive rack.  This one will isolate the vibrations coming off the hard drive better, and holds 4 drives vs the old 3 drive rack.  Metal still needs a little cleanup.  The discoloration you see is just from me running a wire wheel over it to remove some imperfections.
I have a design decision to make.  I figured out where I can fit a laptop sized optical drive without compromising any of the other design elements.  It fits like a freaking glove I'm impressed.  I'm just debating whether I want to spend the $80 or whatever a slot loading DVD-RW would cost me.
Thoughts?
« Reply #12 on: September 16, 2008, 08:35:16 PM »
At this point I'd say just go external.  If you rarely use it anyway then why ruin the build's beauty?
endscape
« Reply #13 on: September 16, 2008, 08:54:57 PM »
It would be a slot below the motherboard backpanel.  I dont think it would ruin the build.
    • The Site Of Doom
« Reply #14 on: September 17, 2008, 11:51:17 AM »
Does it have to be a slot load drive, or would a conventional laptop drive work?
« Reply #15 on: September 17, 2008, 11:59:47 AM »
But do you really want to be giving your PC the reacharound to put in a CD?  Seems like a pain to me.
« Reply #16 on: September 17, 2008, 12:49:47 PM »
But do you really want to keep an external drive lying around connected to it all the time to put in a CD? Seems like a pain to me.
It's easier to move / carry around / LAN if you don't have to carry around an external drive.
endscape
« Reply #17 on: September 17, 2008, 02:28:56 PM »
Could do either.  Tray loading would take some more work, but both are doable.  If I'm going to spend the money I might as well go slot loading since it would make it a lot cleaner.  If I found the right deal on a tray loader I would go with that.
For the occasional Windows install or burned DVD it wouldn't be bad.  I rarely use my optical drive, it would just make the whole build a lot more complete.
Exactly!
endscape
« Reply #18 on: September 21, 2008, 03:50:51 AM »
Very minor update.  I've been battling the blocks on the hard drive side of things for three iterations now.  I dont want to waste anymore half inch acrylic, so I have a new plan!  Four corner pieces glued to the side panel.  I'll clamp it into the case tomorrow and drill and tap the holes exactly where I want them.  I will win!
endscape
« Reply #19 on: September 24, 2008, 03:02:53 AM »
Another minor update.
I got the sidepanel screwed on.  The case is 100% structurally finished minus the pump situation.  Next up is lighting and electronics.  After that comes edge finishing, then paint and any exterior modifications that I may or may not have planned...
Pages: 1 [2] 3 4 5   Go Up
Page created in 0.068 seconds with 19 queries.
