  • June 19, 2019, 04:39:55 PM
Author Topic: 2 routers, one DSL connection  (Read 4193 times)
Babangida
« on: July 24, 2008, 09:15:44 AM »
Hi
I have Verizon DSL service.
I am currently using an Apple Airport Extreme N router.
It is set to put out a signal that is usable by both G/B/N devices.
I would like to have it set up so the Airport Extreme sends out a stronger, N only signal, and set up a second router, an old linksys B, to send out a B signal for devices that are only compatible with that.
Any advice would be greatly appreciated.
Thanks
    • The Site Of Doom
Re: 2 routers, one DSL connection
« Reply #1 on: July 24, 2008, 10:21:11 AM »
Hook one of the LAN ports from the Airport Extreme to one of the LAN ports on the Linksys router. It will work just fine, make sure to disable the DHCP server on the Linksys router first
Page created in 0.056 seconds with 19 queries.
