  • June 05, 2020, 09:03:49 PM
Author Topic: Stealth Drive LED Re-Route  (Read 7664 times)
aceuk
« on: July 05, 2008, 11:46:00 AM »
Hi
I read this guide http://www.gideontech.com/content/articles/207/1
What I want to know is can I replace the Led & switch with a Bulgin switch with ring Led.
Thanx
njbrad
Re: Stealth Drive LED Re-Route
« Reply #1 on: July 05, 2008, 02:03:49 PM »
Shouldn't be any reason to give you trouble.  The key phrase in their spec's is "Separate LED Terminals".
Post pics of your progress.
aceuk
« Reply #2 on: July 06, 2008, 02:03:49 AM »
The only thing I not sure about is the Led on the switch being the same rating as the one in the drive.
    • The Site Of Doom
« Reply #3 on: July 06, 2008, 08:51:16 AM »
One thing you can do is measure the voltage across the legs of the LED in the drive and then compare that value to the spec for the switch/led combo.
If you wanted to play it safe you could use a optoisolator attached to the cd/dvd drive to control the LED and then drive the LED with an alternate power source, freeing you from the voltage/amperage limits imposed by the cd/dvd drive design.
« Last Edit: July 06, 2008, 08:58:05 AM by MaxamusCrasious »
aceuk
« Reply #4 on: July 06, 2008, 10:19:00 AM »
Sorry but what is a optoisolator.
Also if I use an alternate power source for the Led on the switch ,it would be just a light and not show the activity of the drive.
Any idea how much a small meter to measure the voltage would cost.
    • The Site Of Doom
« Reply #5 on: July 06, 2008, 05:01:09 PM »
A optoisolator works by using (generally) a LED and a photo-reciever (i think that is what it is called) to switch a circuit on and off without the circuits being electrically connected. If used properly you could rig it up so every light in your house flashed on and off with CD/DVD activity.
They are used a lot with microcontrollers that need to drive motors or a large array of lights because the current that can be sourced
http://www.ee.ttu.edu/lab/robot/opto.htm here is a little page that explains how they are used with some sample schematics.
http://www.radioshack.com/product/index.jsp?productId=2103174&cp=&sr=1&origkw=multimeter&kw=multimeter&parentPage=search I used this particular meter for quite a bit of time (until I dropped it down the stairs) and it worked great for most electronics projects.
« Reply #6 on: July 07, 2008, 10:17:24 PM »
See if this article by some bozo helps you with the optoisolator question:
http://case-mods.linear1.org/how-do-i-use-an-optoisolator-or-optocoupler-to-run-more-hard-drive-leds/
« Reply #7 on: July 08, 2008, 07:55:42 AM »
Lol, bozo.
« Reply #8 on: July 08, 2008, 03:20:56 PM »
You know Larry Harmon died last week. :(
Page created in 0.225 seconds with 32 queries.
