  • August 16, 2022, 11:08:32 PM
Author Topic: double video card cooling  (Read 19594 times)
« on: June 15, 2008, 01:19:52 PM »
alrighty, now that its summer and the weather is hot, i figured i would check on my case temperatures once again
it turns out that in my sli system, one of the video cards is running about 50% hotter than the other (44c and 60c)
both are passively cooled 8600s, but i wonder if that is too much. if it is too much, are there any SLI cooling systems available? i know there are plenty of single card coolers, but i cant seem to find some systems for multiple cards...
Re: double video card cooling
« Reply #2 on: June 15, 2008, 02:08:10 PM »
http://www.gideontech.com/content/articles/191/1
Old one, but a good one.  I was about to just suggest a fan, but looks like someone else beat me to the punch and with a better recommendation.
« Reply #3 on: June 15, 2008, 04:52:31 PM »
hm, the thing about that is my case already has 2 80mm fans built into the side panel that are right over the VCs. (along with the usual 120 at the front and 120 at the back of the case).
what i am seeing is that the hot air rises up from the bottom card and heats the top. after it goes to the second one it escapes through the back of the case, but by then its too late as the second card is already heated.
now that i look at the arrangement though there might be some space to squeeze in a backplate of the case sideways fan, maybe i will give that a try
« Reply #4 on: June 15, 2008, 07:55:56 PM »
Can we get a picture? Maybe you need to force more air in between the cards to push the hot air out the back or just throughout the rest of the case.
« Reply #5 on: June 15, 2008, 08:27:10 PM »
http://www.flickr.com/photos/misterecentric/2581837549/
ps: those wires arent in the way, its a trick of the camera angle. note the door fans on the left.
« Last Edit: January 24, 2009, 03:55:37 PM by urgannagru »
TheM@trix
« Reply #6 on: June 16, 2008, 10:00:07 PM »
Have you changed the thermal paste or is it stock?
« Reply #7 on: June 17, 2008, 02:04:38 AM »
its stock, and changing it is probably where i would begin. i just figured since one of them is 20c more than the other it might be something to do with my configuration. maybe i will just use 2 standard aftermarket coolers, i didn't know if there was anything made for SLI or small enough to work with sli.
TheM@trix
« Reply #8 on: June 17, 2008, 12:43:06 PM »
Clean and reapply AC3 or 4 or whatever it is now. Maybe the HS just needs to be mounted better on the hotter one?
reign16
« Reply #9 on: January 24, 2009, 03:16:45 PM »
that is an beautiful video of an card cooling man...
___________________
Great thing to know about Busby SEO Test.
Page created in 0.148 seconds with 33 queries.
