  • April 21, 2019, 09:08:06 PM
Pages: [1] 2 3   Go Down
Author Topic: Phenom OC  (Read 16834 times)
    • The Site Of Doom
Phenom OC
« on: May 02, 2008, 05:50:37 PM »
So, the other day I decided to see how far I could push my Phenom 9500 on stock cooling. Monday I bumped the mult from 11 to 11.5 giving me a 100mhz oc to 2.3ghz. Machine ran rock solid for the past week, so a few min ago I bumped it up to 12x putting me at 2.4ghz. Still running great, and I will be pushing the machine hard over the weekend to see how stable it  is and if I could push it to 12x giving me 2.5ghz
Overall, I am wondering if the HT bus speed difference (200mhz) between the phenom 9850 black and my 9500 going to make much of a performance difference seeing as they will have the same clock speed? If there will be a major difference, how much oc-ing can the HT bus take?
    • The Site Of Doom
Re: Phenom OC
« Reply #1 on: June 13, 2008, 02:32:16 PM »
I finally decided to take the OC a bit further, and am now stress testing the cpu at 2.9Ghz. Hopefully it will make it to 3Ghz or higher. It just seems odd to me when I am able to bump the CPU 100mhz at a time and it takes it like a champ.
One change I did make was the move from stock cooling over to a Cooler Master Hyper 212 HSF and Antec Formula 5 compound (The guy at the store swore it was the same as AS5)
TheM@trix
Re: Phenom OC
« Reply #2 on: June 13, 2008, 03:54:18 PM »
What's your HT Multiplier set to?
    • The Site Of Doom
Re: Phenom OC
« Reply #3 on: June 13, 2008, 04:06:47 PM »
14.5
    • The Site Of Doom
Re: Phenom OC
« Reply #4 on: June 13, 2008, 06:18:13 PM »
Well, the burn in at 2.9Ghz passed with flying colors, and the system posted and is currently testing at 3Ghz
I currently am running at a 200mhz FSB and a 15x multiplier
TheM@trix
Re: Phenom OC
« Reply #5 on: June 13, 2008, 09:50:04 PM »
You could probably get more stability if you lowered it to 8x, and your HT bus multiplier to 3 or 4x.
Re: Phenom OC
« Reply #6 on: June 13, 2008, 10:01:49 PM »
14.5
IIRC from S939 days, the HT multiplier only went to x5; I'm guessing that's the CPU multiplier, or that's the Phenom Spinal Tap edition, although doesn't that one only go to x11?
    • The Site Of Doom
Re: Phenom OC
« Reply #7 on: June 13, 2008, 10:09:29 PM »
I'm still getting used to these HT over clocking methods, I don't quite understand all the various multipliers and ratios and such. But  I am reading about it more and more.
I have manged to get the system running stable at 3.2Ghz now, using the default 200Mhz bus and a 16x multiplier. It does not seem to be getting that hot though, 74 idle, and a guess of the mid 80s full load (no temp sensors running in Linux yet)
Melancholinpolly
Re: Phenom OC
« Reply #8 on: June 14, 2008, 12:47:18 AM »
if i'm understanding you correctly. 74c idle is not a good temp to be "idling" at.
Re: Phenom OC
« Reply #9 on: June 14, 2008, 01:11:45 AM »
i assume he means fahrenheit
Pages: [1] 2 3   Go Up
Page created in 0.051 seconds with 19 queries.
