  • July 03, 2020, 10:45:51 AM
Author Topic: 4ghz limit?  (Read 5146 times)
SharonB
4ghz limit?
« on: March 31, 2008, 02:11:07 PM »
I have a P4 cedar mill 631 (holding me over for a few more weeks till q9450) and I have been getting pretty brave with it now that I know I'm going to get a new processor, but I seem to have hit a limit of exactly 3.99ghz. Why? I messed with the voltage of the cpu ( all the way to the max Intel said was safe 1.325V). Is it a ram problem maybe or have I just hit the limit of the cpu. It boots all the way to windows at 4.27ghz but instant bsod. I know its not a heat problem ( or I'm pretty sure its not a heat problem) because in the bios it says about 35C. Anything I can do to maybe get the speed above 3.99ghz. It works great at 3.99ghz, no problems at all and it helps so much its not even funny.
I hope the q9450 doesn't have the same problem (I'm sure it wont)
Other info:
FSB: 275-280
Mobo: Asus Maximus Formula
RAM: Gskill 1000mhz ( hope thats not the issue because it was such a good price)
bliq
Re: 4ghz limit?
« Reply #1 on: March 31, 2008, 04:34:57 PM »
Other info:
FSB: 275-280
Doesn't sound like anything other than you hitting the wall for whatever reason.  RAM? Capacitor quality?  Power?  Heat?  regardless, sounds like a good overclock at 3.99 for that core.
Page created in 0.062 seconds with 33 queries.
