  • July 07, 2020, 01:54:23 AM
Author Topic: P5N32-E Northbridge Overheating...  (Read 14415 times)
Re: P5N32-E Northbridge Overheating...
« Reply #10 on: January 11, 2008, 06:44:45 PM »
I have to wonder if there is anything in the heatpipe.  If the coolant was left out somehow during manufacturing, then it would be useless.  I agree that if it's hot enough that you can't touch it, then there is something definitely wrong.
arjo_reich
« Reply #11 on: January 11, 2008, 07:25:38 PM »
Before I left the office I ordered...
2 x Tt Extreme Spirit II
(figured I might as well plop on the southbridge as well so I can remove both sets of heatsink/heatpipe rigs on the m/b)
1 x Thermalright I/O Side MOSFET Heatsink (HR-09U Type 2)
1 x Thermalright Up Side MOSFET Heatsink (HR-09S Type 2)
:sigh: that it for this rig's budget for a while, lol.
arjo_reich
« Reply #12 on: January 18, 2008, 05:38:21 PM »
I finally got the Tt Spirit Extreme II's in the mail and just finished the installation of them.  man, I have to tell you, the thermal adhesive they use is rock hard and has a tensile strength that will really make you cringe a bit when you hear the way it "snaps" off.  :shudder:
I also had to mod the stock video card cooler by grabbing a hotknife and carving out a small port to allow the posts of the new chipset cooler to fit inside it - was preventing the video card from seating properly in the PCI-e slot...
MCP55XE chipset is reporting only 49C now...
« Last Edit: January 19, 2008, 11:09:37 AM by arjo_reich »
« Reply #13 on: January 18, 2008, 09:50:05 PM »
Your links to enlarge the pics don't work, but oh well.  Glad you got it working. :thumbsup:
« Reply #14 on: January 19, 2008, 01:10:05 AM »
if you edit the links with a bit of trickery the images are there
for example,
http://i87.photobucket.com/albums/k156/arjo_reich/computers/overclocking/new%20coolers/new_coolers_09.jpg
not the
http://"http//i87.photobucket.com/albums/k156/arjo_reich/computers/overclocking/new%20coolers/new_coolers_09.jpg%22
that opens up once you click on the original link
arjo_reich
« Reply #15 on: January 19, 2008, 11:10:30 AM »
I fixed the links, apparently the forum doesn't like quoted urls in the url tag... :shrug:
