  • July 07, 2020, 01:46:38 AM
Author Topic: Calling all CM Stacker 830 owners!  (Read 2515 times)
Para Monkey
« on: December 15, 2007, 02:18:59 PM »
I'm looking to pick up this case for my water cooling setup - which I already own most of the components for. I have a dual 120mm radiator I plan on using, is there a convenient place in this case to mount it?
Based on pictures and what research I could perform, I was planning on mounting it on the front behind the drive bay shields, making modifications to the HDD enclosure if needed. Otherwise, the plastic quad fan holder might work... but I don't want it to be a PITA every time I need to get into the case.
Any suggestions or thoughts? I'm also looking at the thermaltake Armor case series, looks to be plenty more room and options in that case - but I really like the look of the stacker!
Re: Calling all CM Stacker 830 owners!
« Reply #1 on: December 15, 2007, 02:24:02 PM »
I don't have one, but I would recommend asking here also.
Page created in 0.081 seconds with 33 queries.
