  • January 16, 2019, 10:18:01 PM
Author Topic: Clear Hdd enclosure  (Read 16574 times)
Glitch
Clear Hdd enclosure
« on: November 25, 2007, 02:57:10 PM »
Hey guys itís been a while since I was on but Iíve been busy. I recently got an external HDD enclosure and at first it seemed ok but the lack of ventilation in it came back to haunt me. After a few days my HDD died on me due to heat. So I decided to make my own enclosure out of acrylic after being inspired by the one Dave did. It has a 120mm intake fan controlled by a switch because itís going to be running off the stock PSU, so Iíll only use it when I need it.
E8400 w/ Freezer pro 7
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
Glitch
Re: Clear Hdd enclosure
« Reply #1 on: November 25, 2007, 02:59:56 PM »
Tried to upload the pics but it won't go thru  :-?. Will upload them later
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
Glitch
« Reply #2 on: November 26, 2007, 07:08:01 PM »
First pic is the original enclosure the rest are quick mockups
« Last Edit: November 26, 2007, 07:13:13 PM by Glitch »
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
Glitch
« Reply #3 on: November 26, 2007, 07:08:54 PM »
Just had the feet installed. Also did the cuts for the ports in the plexi, the last pic is a test fit of the hdd cage
« Last Edit: November 26, 2007, 07:14:22 PM by Glitch »
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
Glitch
« Reply #4 on: November 26, 2007, 07:11:14 PM »
The back with ventilation holes and switch for the fan installed. The last pic is the 120mm fan i'll be using with the mounting feet i'll be using to secure the sides
« Last Edit: November 26, 2007, 07:16:40 PM by Glitch »
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
Glitch
« Reply #5 on: November 26, 2007, 07:12:09 PM »
Quick mockup of the box before final assembly. I removed the paper backing couldn't resist  :P
« Last Edit: November 26, 2007, 07:17:43 PM by Glitch »
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
Glitch
« Reply #6 on: November 26, 2007, 07:18:58 PM »
Final assembly whoooo!!... well not final assembly still some work to be done but its 95% completed
« Last Edit: November 26, 2007, 07:25:36 PM by Glitch »
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
Glitch
« Reply #7 on: November 26, 2007, 07:27:38 PM »
First pic is the unit on with fan, second is without fan and third is read/write (without fan)
« Last Edit: November 26, 2007, 07:30:53 PM by Glitch »
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
« Reply #8 on: November 26, 2007, 07:35:16 PM »
Nice looking and good job on it.
I have gotten a lot of USB external enclosures and none killed a HDD.
« Reply #9 on: November 26, 2007, 07:59:55 PM »
I've had them kill drives before. Usually it happens via power spikes or overheating, generally the latter.
Page created in 0.06 seconds with 19 queries.
