  • February 25, 2021, 10:54:49 PM
Author Topic: How to trick the control board about fan's RPM without running the fan?  (Read 13712 times)
6_6_6
Hello Folks,
I would like to supply the fan's rpm to the controller board. Constant or variable rpm does nto matter but it should not be zero.
The fan has a 3-pin header (Y-R-B) going into the control board. Yellow carries signal/sense/rpm to the control board as far as i can see.
What I am trying to do is to run my Zalman Reserator XT kit without the fan. It won't run when the fan is not spinning.
What can i do to relay a fan speed to the control board without running a fan?
Thank you in advance for your time.
Maria
Re: How to trick the control board about fan's RPM without running the fan?
« Reply #1 on: October 19, 2007, 06:18:58 PM »
What motherboard do you have?  Are you sure you can't turn that protection off in the BIOS?
6_6_6
« Reply #2 on: October 19, 2007, 06:23:31 PM »
Mobo is not important. The fan is not connecting to the mobo. It is connecting to an external unit's control board.
damaged
« Reply #3 on: October 19, 2007, 06:37:07 PM »
http://www.formfactors.org/developer%5Cspecs%5Cmatxspe1.2.pdf   page 22
http://pinouts.ru/Power/wtxadd_pinout.shtml  Shows 22 pin mobo connector pinout
(If you had a fan you could split the signal from pin 20 to your external circuit)
Hope this can help somehow
6_6_6
« Reply #4 on: October 19, 2007, 07:32:29 PM »
Hello damaged,
I am not connecting it to a motherboard or 22 pins...
The fan has 3 cables: Y-R-B... and it connects to the circuit board which also has 3-pins: Y-R-B.
So question is: How to use any device to relay the rpm signal (Yellow wire) to the Y-pin on the control board in order to eliminate the fan altogether without setting off the alarms.
6_6_6
« Reply #5 on: October 19, 2007, 09:27:45 PM »
What happens if I jumper the pins YELLOW (signal) and RED (power)? Could that trick the controllor board thinking the fan is always on and spinning?
damaged
« Reply #6 on: October 19, 2007, 10:07:17 PM »
The first link i gave you should start you off... you need to give it 2 pulses (+5vdc) per rev, so find the minimum revs needed before your device shuts down... i'm not real sure beyond that.
i7dude
« Reply #7 on: October 22, 2007, 03:30:04 PM »
no. that wont work.  the shortest and simplest solution to your problem would be to design a small circuit that send square wave pulses to the "YELLOW" pin at a frequency proportional to the RPM's of the fan you are looking to fake.
This can be done by using a 555 timer circuit for mere pennies!
Now, all you need to do is figure out what frequency the pulses need to be, then do a google search for 555 timer circuit, there are LOTS of examples on the "internet".
dude.
ClearCaseMan
    • http://www.casemodman.com
Page created in 0.611 seconds with 33 queries.
