  • December 06, 2019, 02:18:06 PM
Author Topic: Possible To Fix These Scratches On My CM Stacker?  (Read 21870 times)
robertsmith1
Re: Possible To Fix These Scratches On My CM Stacker?
« Reply #10 on: October 16, 2007, 06:04:41 AM »
To clarify, the scratches are only one the painted part on the circled area of the picture.  It is not aluminum but steel with silver paint on it.
The side panel is brushed aluminum but that is NOT scratched.
There is also no plastic in the vicinity of the scratch.
« Last Edit: October 16, 2007, 06:07:46 AM by robertsmith1 »
josh009
« Reply #11 on: October 16, 2007, 11:16:29 AM »
Well, then you can try polishing it like a car, as someone else said.
I thought we were talking about brushed or coated aluminum.
« Reply #12 on: October 16, 2007, 11:59:49 AM »
Go to the local auto store and say you want to try an buff out some small scraches. They should be able to point you to the right stuff.
Case painting is done alot like cars so it all should work.
Page created in 0.057 seconds with 19 queries.
