  • July 06, 2020, 12:55:43 AM
Author Topic: simple function generator  (Read 4118 times)
neostar63
« on: September 18, 2007, 10:42:37 AM »
Looking for a low cost function generator that can do a square wave between 50 and 100Hz at 5V p to p. I know a 555 circuit can do this easily, this will be used as test equipment so they are looking for something that they can just buy and not make. I was wondering if maybe someone knew of a little box that someone sold that just put out a constant square wave. The frequency does not need to be variable nor does the voltage.
i7dude
Re: simple function generator
« Reply #1 on: September 18, 2007, 10:58:27 AM »
if the voltage and frequency need not be variable, then the 555 timer circuit will be the fastest and cheapest way to get what you need.
dude.
neostar63
« Reply #2 on: September 18, 2007, 12:47:21 PM »
this has been totally realized, but it seems that they are reluctant to go with a in house built solution.
i7dude
« Reply #3 on: September 18, 2007, 01:32:11 PM »
search for "square wave generator" on e-b-a-y.
in all honesty, you're acquaintances thought process is pretty foolish.  they are going to waste a lot of time and money procuring something they could have up and running in under 10 minutes for less than a dollar.
dude.
neostar63
« Reply #4 on: September 18, 2007, 04:25:10 PM »
Figured out why it needs to be an actual function generator. It is so that they can slap a calibration sticker on it.
Page created in 0.068 seconds with 33 queries.
