  • July 15, 2020, 02:18:46 PM
Author Topic: 4 Pin Fan PWM Fan Control  (Read 3006 times)
FormatC
    • Peter's Wacky World
« on: September 15, 2007, 02:19:16 PM »
I found a great deal for 80 MM PWM Fans which my older case uses and my fans are all old and about to die (Plus there full of cat hair) so I know I can plug these fans into a regular 3-pin MB header or a Molex with the proper adapter? Since these fans put out 59/46 CFM/DBA I want to build a fan bus what would I need to use the PWM circuit already in the fan in my fan bus/Circuit? And if I plug them directly into 12 Volts would they run at full speed?
on earth
Page created in 0.08 seconds with 34 queries.
