  • August 16, 2022, 10:43:55 PM
Author Topic: SLI + Fanless = ?  (Read 7152 times)
SLI + Fanless = ?
« on: September 05, 2007, 10:49:58 PM »
I have a passively cooled video card, and I was thinking about going dual cards + SLI so I could have 4 LCDs rather than just 2, but then I realized I have a passively cooled card.
Will having 2 passively cooled 8600s in the same case cause a heat problem? I have 4x120mm casefans in there, so I would hope not, but I figured I should ask first.
Re: SLI + Fanless = ?
« Reply #1 on: September 06, 2007, 07:27:34 AM »
So long as you keep the air moving around them and out the back, no.  If the air is stagnant, especially between the two cards, then you will have problems.
« Reply #2 on: September 06, 2007, 11:38:13 AM »
That was pretty much my hunch, which its good to confirm, but I was curious if anyone here has tried it and if its worked out for them
Page created in 0.332 seconds with 33 queries.
