  • June 05, 2020, 09:31:34 PM
Author Topic: wierd shaped windows  (Read 5760 times)
NMDante
  • Aaargh!
« Reply #10 on: August 06, 2001, 09:35:00 PM »
Liquid nails...yummy.  That stuff is strong.  Goop is strong too.
Just let the adhesive dry at least 12-24 hrs before doing anything else.  A few clamps will help as well.
warriorx1
    • http://warriorx.tripod.com/
« Reply #11 on: August 07, 2001, 10:47:00 AM »
cool!
making my shopping list now... :)
i'm going to work on this over the next few nights once i get a good drawing of the slashes down. thanks for all your tips... i'll posts some pics when i get done (hopefuly this weekend).
TitoJackson
« Reply #12 on: August 10, 2001, 06:41:00 PM »
I wouldn't use the silicon adhesive.  It's plenty strong, but you don't need an adhesive that is terribly strong.
DougthaThug
« Reply #13 on: August 24, 2001, 12:34:00 PM »
A quick suggestion,
if you dremel it, make sure you use masking tape over the edges of where you want to cut so you don't scratch the paint with the wheel or with flying debris. Or cut it out from the other side.  Also highly recommend goggles (or face shield - suprisingly cheap) and a dust mask.
Page created in 0.819 seconds with 33 queries.
