  • October 19, 2019, 02:16:08 AM
Author Topic: Could I build my own VGA switch?  (Read 9551 times)
KoRn Addict
  • It's not METAL enough!
« on: August 04, 2007, 11:24:03 PM »
Since I'm having a difficult time finding something that will work, maybe I can make my own, eh?
The main requirement would to be able to support a signal resolution of 1680x1050. Also, if you suggest a KVM instead, a physical switch is required for independence of attached devices.
The way I figure, would this not be too difficult to get a >= 15 pin relay, or at least a hierarchy of less-endowed relays, build a box, and use a generic wall-wart for relay power.
Does anybody have any opinions or suggestions?
Re: Could I build my own VGA switch?
« Reply #1 on: August 05, 2007, 12:03:27 AM »
You might look for an older one; I'm sure I've seen then in the computer graveyards.
meander
« Reply #2 on: September 07, 2007, 05:26:15 AM »
when i looked inside the older switch i had a while back alls it was was a 15 pole switch, and each of the wires went through that. although if you do build one, make sure you sheild the wires inside somehow, lest you get ghosting on the monitors, thats what the problem with mine was
i7 M 640, 8GB DDR3, 500GB SATA2, nVidia 330M
M=C2D E6850, 4GB DDR2, 320GB SATA2, 8800GTS Superclocked
ClearCaseMan
    • http://www.casemodman.com
« Reply #3 on: September 07, 2007, 12:48:39 PM »
with the newer kvm's they use transistors to switch the signal. where the older ones use a actual switch. your problem is going to be noise.you might be able to find a old switch, but I think you will still have shielding issues. Rob (Linear) would be the one who could answer this for sure. what kind of "independence of attached devices" do you need?
KoRn Addict
« Reply #4 on: September 08, 2007, 03:08:38 PM »
Well, originally it was for an Xbox 360 being hooked up into the VGA port of my monitor, being shared by my laptop, but things have changed and 360's now have HDMI and that will work for my DVI port, so my troubles are gone. Thanks anyway CCM.
Page created in 0.055 seconds with 19 queries.
