  • January 24, 2020, 04:06:08 AM
Author Topic: Wanting to build a case need advice  (Read 6126 times)
baggedmazda
« on: May 30, 2007, 05:43:28 AM »
buddy installs glass and can get me the plexi and bonding glue for free what should i know if i decide to do this i kinda want some thing like the danger den air box but probly more fans and some room to go water if i decide to or i could build a little case for that stuff too.
I am looking at building a new gaming system in the next couple months so i thought i may wana do this first.
Re: Wanting to build a case need advice
« Reply #1 on: May 30, 2007, 06:51:11 AM »
First would be to come up with a design.  SketchUp is a great and easy to learn program to help you come up with your idea.
baggedmazda
« Reply #2 on: May 30, 2007, 05:38:20 PM »
nOObee
« Reply #3 on: June 12, 2007, 01:31:09 AM »
1-Learn to construct proper sentences and use proper punctuation.  Trying to read that just gives people a headache.
2-Google for Plexiglas computer cases and see what's out there.  You'll get some great ideas.
3-For your first plexiglas case, I'd recommend the K.I.S.S. principle.
4-When you come up with something more definitive, there are several people here who can get you through the tricky parts.
Good Luck!
« Reply #4 on: June 25, 2007, 03:09:48 PM »
LMAO :D...but seriously, what does your buddy installing glass have to do with plexi?  I take it they work with more than just glass.
« Last Edit: June 25, 2007, 03:11:21 PM by wonko »
Page created in 0.07 seconds with 33 queries.
