  • December 15, 2019, 01:18:19 AM
Author Topic: Holesaw for 120mm fan?  (Read 3186 times)
cnc10
« on: May 10, 2007, 03:07:27 AM »
I was wondering what size holesaw I need for a 120mm fan.  I see that a lot of people use the 4.5 inch holesaw, but that is smaller than 120mm.  How do I make a 4.5 inch holesaw work for a 120mm fan?  Do I have to use a dremel or a nibbler to cut the hole to size?
I love E. Coli Burritos.  Over and out.  SCHHTTTT
Re: Holesaw for 120mm fan?
« Reply #1 on: May 10, 2007, 06:11:01 AM »
A 4.5" holesaw is a ~114mm.  It's only 5% smaller than the fan which in the grand scheme of things does not matter.  Just use a 4.5" holesaw and be done with it.
pinkpanther
« Reply #2 on: May 11, 2007, 07:45:02 AM »
File, dremel with a abrasive disc, and lots of patience.  Also, a new holesaw might be a little larger than the 4.5" mark; so you'll get around 115-117 mm.  So yeah, use a hole saw and be done with it.   :)
nOObee
« Reply #3 on: May 14, 2007, 03:56:39 PM »
A hard-to-find 4 5/8' holesaw would be perfect, IF you could drill with zero wobble and runout.   Like they say, use the 4.5.  You'll be glad you did. ;)
cnc10
« Reply #4 on: May 14, 2007, 07:36:16 PM »
Thanks for the tip nOObee.  I found the 4 5/8" holesaw and was wondering why not to use it.  I almost ordered it then I decided I would ask.  Makes sense now.
Page created in 0.059 seconds with 19 queries.
