  • July 14, 2020, 09:11:45 AM
Author Topic: simple logic gate usage  (Read 2996 times)
trials_modder
« on: May 01, 2007, 03:10:54 AM »
hi
i'm wondering how to use the 4000 series and 74* logic gates. from the data sheets i've established where Vcc and ground are hooked up, where to hook up the actual inputs/ouput for a single gate, but when i check the output with my multimeter the results aren't expected.
btw, i'm using the 4081 AND and the 74Ls00 NAND gates for testing
to make that clearer - how do i design the inputs so they can switch between a high and low state? i can physically move the input wire between + and gnd, but i don't want to do that
after much googling, i think i got it:
http://www.allaboutcircuits.com/vol_6/chpt_7/2.html
« Last Edit: May 03, 2007, 06:30:11 PM by viridius »
LOUD ANGRY NOISES
Re: simple logic gate usage
« Reply #1 on: May 03, 2007, 06:32:26 PM »
Some logic design tips:
Regulate and decouple your power supply with a voltage regulator chip and a capacitor.
Tie the inputs of unused gates high or low (don't let them float).
Use pull-up or pull-down resistors (also to avoid floating inputs).
trials_modder
« Reply #2 on: May 03, 2007, 11:42:15 PM »
yeah, i seem to be having troubles combining a CMOS and TTL logic gate together, I think I"ll just go buy some CMOS equivalents of the TTL chips to make things easier :p
LOUD ANGRY NOISES
rafununu
« Reply #3 on: May 04, 2007, 05:08:50 AM »
Don't forget, always connect inputs either to GND or VCC, even through a resistor. Concerning TTL and CMOS, CMOS inputs are TTL compatible provided supply doesn't exceed 5V.
trials_modder
« Reply #4 on: May 04, 2007, 11:35:06 AM »
ok, i'll take another stab at building the circuit. should there be any special connections (pulldown resistors?) between the TTL output and CMOS input, or will TTL act as ground?
LOUD ANGRY NOISES
Page created in 0.107 seconds with 33 queries.
