  • July 15, 2020, 02:22:14 PM
Author Topic: And yet another Remote PC Start idea...  (Read 6854 times)
nQuirer
« on: April 21, 2007, 09:16:08 AM »
I read your guide on the remote start mod and I think it's incredible.
Then after reading it, I stumbled upon this little number:
http://www.svc.com/rm02.html
Which got me to thinking... (oh noes!)
Couldn't that device be used in combination with a WOL cable to create a pretty clean remote start?
I could be way off base, and if I am, by all means, do tell.
But if I'm not, how would the wiring go?
Or would the device need to be modified?
Any help would be greatly appreciated. [:
Re: And yet another Remote PC Start idea...
« Reply #1 on: May 03, 2007, 06:39:43 PM »
Possible, but the relay might draw too much power for the WOL header.  Maybe replace it with a solid state circuit?
Ronin
  • GURNING ALL WAY HOME.
« Reply #2 on: June 26, 2007, 09:45:31 AM »
What about bluetooth and a phone that could send something to wake it up like WOL
WOB?
I use my phone to listen to my pc with media player and use my phone to control the mouse.
Tried to play CEASAR4 on it, quite and lengthly process but it worked non the less. :D
Iv3 b33n H4x0r5.
Page created in 0.067 seconds with 34 queries.
