  • February 25, 2021, 10:15:15 PM
Author Topic: Question on a Electronic Combination Lock  (Read 4035 times)
REK636
  • Is the pie evil?
« on: April 08, 2007, 02:42:05 AM »
I'm trying to find somthing to take up my 3.5 panel. I'm looking at this circuit and im thinking about using it to turn on a computer. Would putting in a optocoupler work insted of the relay and can you tell me how it works. I'm goint to use a 9v battery so I dont have to run a second cord.
http://www.free-electronic-circuits.com/circuits/electronic-combination-lock.html
Why is it grounded after the switches?
I have no electrinic experience and I would like to try somthing and learn hopefuly not from a mistake.
One of the great things about books is sometimes there are some fantastic pictures
Re: Question on a Electronic Combination Lock
« Reply #1 on: April 09, 2007, 01:17:20 PM »
That's kind of neat, but it would probably be easier to use a 4017 or something.  An optocoupler would work in your application.  The grounding after the switches is to pull them low and force a logical "0" when they aren't pressed.  Otherwise, you could get false triggering.  I have a working schematic for a combination lock with a dial if you're interested.
REK636
  • Is the pie evil?
« Reply #2 on: April 09, 2007, 05:08:52 PM »
sure...dont know whayt you mean by dial. you me a selector dial?
« Reply #3 on: April 10, 2007, 07:21:38 PM »
More like a combination lock you'd find on a gym locker or something.
REK636
  • Is the pie evil?
« Reply #4 on: April 12, 2007, 06:19:40 PM »
how does that work with one dial and then you select with a button or with multiple dials ?
the one dail  thing might work insted of using several push button switches on the pannel giving me some room.
« Reply #5 on: May 03, 2007, 06:36:17 PM »
Sorry I've taken so long, it's been kind of busy around here.  My original prototype had a RC delay circuit that would only "enter" the number after a few seconds had passed.  So: spin the dial to a number, wait a few seconds, spin the dial to another number, wait a few seconds, spin the dial to the last number, wait a few seconds and the output signal of the lock goes high.
Page created in 0.062 seconds with 33 queries.
