  • January 16, 2019, 10:04:48 PM
Author Topic: 640MB Gainward 8800GTS Bliss airflow direction  (Read 2800 times)
deejayry
    • http://members.lycos.co.uk/ryanparle
« on: January 28, 2007, 01:33:45 PM »
Does anyone know whay way the air flows through this vid card? ideally i need the warm air to be exhausted through the back panel, i'm worried that if it pulls cold air in it will mess up the airflow in the enermax CS-718 case i'm planning on getting at the same time.
Re: 640MB Gainward 8800GTS Bliss airflow direction
« Reply #1 on: January 28, 2007, 02:24:34 PM »
easiest way to find out would be to stick your hand near one end and see if the air is blowing on your hand or not
of course, i assume you are asking because you are thinking of getting one, so my tip isnt exactly helpful
most likely it blows air out of the system, i cant think of anything that exhausts into the case if it has any other option
« Reply #2 on: January 29, 2007, 11:02:41 AM »
out the back.
Page created in 0.052 seconds with 18 queries.
