  • June 24, 2019, 03:04:20 PM
Author Topic: Extending PSU Leads... Caps????  (Read 1244 times)
Theytonn
« on: January 18, 2007, 12:05:39 AM »
I am in the process of building a custom case, and my optical drives will be apart from the main casing. I will have to increase the PSU leads by 15 to 20 inches. What I need to know is, do I need to put capacitors on the leads? If so, what rating? I know enough of the electical theory to get by, but this is beyond my scope. In case its need to know info, each drive will have its own leads and I am thinking of putting a 40 or 60mm fans in the casing (one for each drive).
Any/all input will be appreciated. Thanks ahead of time.
Theytonn.
    • The Site Of Doom
Re: Extending PSU Leads... Caps????
« Reply #1 on: January 18, 2007, 12:12:19 AM »
Nope, all you need to do when you are extending the leads are to use the same (or at least close) gauge wire, and to properly secure your connections (solder, low loss crimp, twist and tape)
Theytonn
« Reply #2 on: January 18, 2007, 12:16:38 AM »
Thanks MaxamusCrasious.
« Last Edit: February 09, 2007, 01:02:28 AM by Theytonn »
Page created in 0.032 seconds with 19 queries.
