  • June 05, 2020, 09:18:10 PM
Author Topic: The Dragon orb 3 is a BEAST  (Read 6909 times)
Kuchuk
« on: August 02, 2001, 12:02:00 PM »
yes this one heavy piece of machinery, but its sooo loud, anyone knows how to make it more quiet?
AdamG
    • http://kinetikclone.com
« Reply #1 on: August 02, 2001, 04:41:00 PM »
yeh, throw it away, for the money, you can get so much better of a hsf!
Vortek
« Reply #2 on: August 02, 2001, 04:48:00 PM »
:lol:
sorry man...that was funny.
« Reply #3 on: August 02, 2001, 07:28:00 PM »
you could reduce the voltage you are giving the fan, from 12 to 7 volts, by adding in a resister.
TitoJackson
« Reply #4 on: August 10, 2001, 06:54:00 PM »
You could wire in a rheostat so you can tune it down when surfing and let it run full blast when you're fraggin at the lan.
Lotek
« Reply #5 on: November 21, 2001, 09:05:00 PM »
harmonic vibrations contribute to noise in a case. the mb and case act like an speaker for them. Im playing with the idea of damping the vibrations with foam pads under the case and maybe a foam gasket between the fan and heatsink. Ill let you know how it turns out.
Melancholinpolly
« Reply #6 on: November 24, 2001, 12:47:00 AM »
is there any non intrusive way to turn down the speed of the fan?
brutal
    • http://www.brutal.tk
« Reply #7 on: November 24, 2001, 01:39:00 AM »
even tho WS's idea of a resistor is best, you could always just wire it as 7volts instead of 12 by using the +5vdc wire instead of the black ground wire.  btw, a rheo is a risk for hsf cooling because you could accidentally turn it down to low to cool and burn up a chip
basic
« Reply #8 on: November 24, 2001, 10:13:00 PM »
yea, i wouldn't rheo it, but if you do, make sure when you turn it all they way done the hsf is still running, that would be a good range...i still need to find rheo's that will handle these huge ass 120mm delta's..
