  • September 24, 2020, 07:19:31 PM
Author Topic: Where to get header housings? (Like the kind used For Motherboard LED/Switchs)  (Read 1643 times)
FormatC
    • Peter's Wacky World
I bought an HD44780 VFD  (A Noritake 20 X 4 U Series) and it has a single row 14 pin header soldered on. so the part I'm looking for and having trouble finding is a 12 pin, I can find 2 pin ones every where  but I need one that looks exacly like this Only with 12 Pin Holes
Why you say? Because I already bought the tool to crimp those pins for those exact headers from a previous project, and yet again you say why a 12 pin and a 2 pin because I want to have seperare power and data connections for the VFD. IF worse comes to worse and I can't find them I will probably use a 10 pin and a two 2 pins but I would really like to get the right part and not have not but another expensive crimper
Thanks
on earth
You know what I'd do:
24-pin ribbon cable plug, 24-wire ribbon cable, use every second wire, put one row of the pins over the socket.
Added plus:  The tightness of ribbon cable instead of 12 loose wires.
I usually get those from either digikey.com or mouser.com.  problem is with those sites is that they usually require a minimum purchase.  Last I bought stuff, it was probably $5 minimum.  I would only buy from them if I need a lot of stuff.  If you're gonna end up buying parts like those, buy extra, in case you need more later.  Also, those connectors don't come with the leads/pins.  make sure you buy a lot of extras in case you break them or mess up your crimping.
Page created in 0.112 seconds with 32 queries.
