  • March 31, 2020, 02:53:00 PM
Pages: 1 2 [3]   Go Down
Author Topic: Charging the Zen Micro with a home-made charger - isolating the problem...  (Read 4128 times)
Well, you would calculate the resistor by the equation (voltage drop)/current, but since the current is going to be changing, no one value of resistor is going to work.  If you must drop voltage, use diodes.
trials_modder
9 hours on trickle-charge. Regulator cool. Battery status started at 3 bars, still at 3 bars with no 100% indication symbol.
LOUD ANGRY NOISES
Pages: 1 2 [3]   Go Up
Page created in 0.081 seconds with 34 queries.
