  • June 05, 2020, 07:57:29 PM
Pages: [1] 2 3   Go Down
Author Topic: Charging the Zen Micro with a home-made charger - isolating the problem...  (Read 4184 times)
trials_modder
My current set up: 12v 500mA AC/DC wall transformer feeds a LM7805 voltage regulator (output 5v rated up to 1 A) which in turn connects to the power pins of a usb cord, and the cord is plugged into the Zen Micro. Somewhere along the way a component is failing to hold up its end, causing the Zen Micro to think its charging, but failing to do so (battery level may go up ever so slightly when off (trickle charging?) and apparently doing nothing when the Micro is running.
Apparently each USB port can source 500mA of current, so I don't think its the wall transformer or the regulator not being able to handle the current. However, the process to go from 12v to 5v disappates over half the voltage in the form of heat...
I've plugged a USB light+fan into my device, and it runs perfectly for 10 seconds or so, before it abruptly stops.
If the regulator is the problem, how would I rewire my device to solve the problem?
LOUD ANGRY NOISES
Is the 7805 getting hot?  You might be tripping the thermal protection.
trials_modder
Yeah, over time while attempting to charge the Zen I notice the case its enclosed in becomes exceptionally warm. I figure this regulator is only ~40% effecient, so perhaps it cannot supply enough current.
LOUD ANGRY NOISES
Try putting a heatsink on it and running it outside of the case it is in; see if it lets the light/fan combo run longer.
trials_modder
How exactly does the overheat protection circuit work in the regulator? I just tested the circuit, and the regulator is indeed becoming hot quite fast. It is dumping far too much heat to possibly be efficient or useful; the last thing I want to happen is my circuit's enclosure to become steaming hot...
One idea is to have multiple voltage regulators to slowly step down the input, but that sounds like there should be another way. The enclosure it is in is tiny, so I am slightly pressed for space.
LOUD ANGRY NOISES
njbrad
Try a lower voltage power supply.  If I recall correctly the 7805 will drop a minimum of 1.5 volts.  A 6.5 - 7 volt power adapter should work.  (And the regulator should be a lot cooler)
Brad Bruce
trials_modder
Well if that's the case - why not just get a 5v wall ac adapter? There must be some way...
LOUD ANGRY NOISES
Excess3
If your voltage regulator has been getting that hot it may now be damaged, thus making things worse.  Do you have another one lying around?  If so, try replacing the IC and put a heatsink on it this time, don't forget the thermal paste.
Well if the thermal protection is kicking in, the circuitry of the 7805 should be just fine.  The lower voltage power supply might work, as would just sinking the thing.
trials_modder
I guess no matter what method I use, the 7 volts would have to be converted as heat?  :roll: Unless... I have a few LEDs on there to drop the voltage? Suggestible if its drawing that much current?
LOUD ANGRY NOISES
Pages: [1] 2 3   Go Up
Page created in 0.071 seconds with 32 queries.
