  • January 27, 2020, 05:36:53 AM
Author Topic: How to charge a phone battery pack?  (Read 1218 times)
FormatC
    • Peter's Wacky World
« on: June 02, 2006, 11:47:39 PM »
How do I charge a cordless phone battery pack the phone is long gone and I want to use the battery as an LED tester as it's the perfect voltage for most LEDS (with a resistpr of course) the battery specs are 3.6 Volts 400 Mah NI-CD. do I need a to make a circuit to charge it or can I use a wall adapter from my collection of ac adapters (XX Volts for X amount of time) Thanks
on earth
Re: How to charge a phone battery pack?
« Reply #1 on: June 04, 2006, 03:40:45 PM »
I wouldn't even bother, all you need to test a LED is an AAA or an AA batt. ;)
pinkpanther
« Reply #2 on: June 04, 2006, 05:57:18 PM »
If you're serious about charging it, a trickle charger would probably work best.  They are most commonly used to charge the battery packs for RC vehicles.  I'd give a look into one of those.  They might be rather pricey though.
Page created in 0.082 seconds with 34 queries.
