  • December 15, 2019, 06:36:36 AM
Author Topic: wiring question  (Read 1024 times)
airhead
    • Leet Enterprise!
wiring question
« on: March 28, 2006, 04:46:06 PM »
I made this panel for my computer to turn on and off individual fans, but I have one question.
In the green circle, because both negative ends of the led and the fan are connected in series when the switch is off, will it cause any voltage problems as the motor spins down?
I just realized this might be a problem...but to late
I did test it out in the schmatic program I was using, and the light flickers a couple seconds after the switch is opened, Im thinking this is due to the voltage inbalance due to the consumption by the fan and resistor, so im wondering of this is ok?
current project: modding a server case with
fan controls, status meters, plexi windows, lights
Help me out, and goto
  http://ipods.freepay.com/?r=7443338
To mod or not to mod, that is a stupid question!
Re: wiring question
« Reply #1 on: March 28, 2006, 05:22:20 PM »
No, the loop is 12V to 12V, so no current will flow.
airhead
    • Leet Enterprise!
Re: wiring question
« Reply #2 on: March 28, 2006, 11:58:20 PM »
k, thanks, thats what I thought, but I was a bit worried there would actually be an unbalance
Page created in 0.053 seconds with 19 queries.
