  • February 19, 2020, 09:28:08 AM
Author Topic: How to light only some segments of a 7 led dysplay  (Read 2616 times)
Re: How to light only some segments of a 7 led dysplay
« Reply #10 on: February 19, 2006, 06:22:17 PM »
Buy some 360 ohm resistors and a 9 volt battery.  Connect a lead of the resistor to the positive lead of the battery.  Try connecting the other lead of the resistor and the negative lead of the battery to different pins on the display.  When a segment lights up, leave the negative lead of the battery connected to the pin it is currently connected to and move the resistor lead to a different pin.  If a different segment lights up, it is a common cathode display.  If no segments light up, it is a common anode display.  Play around with the display until you know which pins light up which segments.
bogdan_lupuro
« Reply #11 on: February 20, 2006, 12:23:57 PM »
I see
Thank you...that is what i will do
Page created in 0.06 seconds with 33 queries.
