  • July 09, 2020, 04:59:22 PM
Author Topic: 6600GT Overclocking  (Read 3083 times)
Random
6600GT Overclocking
« on: February 02, 2006, 12:36:34 AM »
Hey i was wondering how i can overclock my geforce 6600GT AGP card?
i am a total n00b at OCing, so detailed help is appreciated.
Also, I was wondering how well the stock cooler on my p4 2.8ghz would be able to handle an oc to 3.0ghz
there is a new game coming out soon that i want to run well, and i cant aford an upgrade, so i want to tweak and OC to beable to play the game
Re: 6600GT Overclocking
« Reply #1 on: February 02, 2006, 12:55:25 AM »
The "Prescott" P4 is said to run hotter than the "Northwood" one. Might check that.
The 6600GT is a also bit hot-running... you might consider aftermarket cooling.  I <3 my Zalman VF700-Cu.
The nVidia control panel has a rudimentary overclocking control panel, run the speeds up slowly.  If the panel isn't shown (display properties->settings->advanced->Geforce 6600GT) check for 'coolbits', a registry tweak which shows the hidden panel.
Excess3
« Reply #2 on: February 02, 2006, 01:35:56 AM »
coolbits (google search it) is the way to go for the Nvidia cards, especially for those new to the whole overclocking thing.  Its as easy as moving a slider bar.  IT even has an "auto overclock" that runs some quick tests to see how far the hardware can safely be pushed..  basically a 1 button overclock for you video card.  Best of all its aleady programmed into the drivers, all you have to do is unlock the option.
« Reply #3 on: February 02, 2006, 03:13:16 AM »
I somewhat doubt that you'd be able to overclock your 6600GT to the point that you'd be able to make a previously unplayable game playable, but I'm frequently wrong.  Rivatuner is a good utility to have, in addition to some benchmarking/stress testing software and the previously mentioned CoolBits reg hack.
Alric_the_mad
« Reply #4 on: February 14, 2006, 05:46:25 AM »
Code: [Select]
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\NvTweak]
"CoolBits"=dword:00000003
There's the the coolbits registry entry for you. It requires a reboot to unlock the OC-ing in the driver.
meander
« Reply #5 on: February 14, 2006, 04:17:02 PM »
i have a 6600gt as well, and i was interested in a new cooler. the Zalman VF700-Cu seems to be the way to go, but i was wondering if it comes with grease, and if left unoverclocked, can it be run on silent mode with this card?
i7 M 640, 8GB DDR3, 500GB SATA2, nVidia 330M
M=C2D E6850, 4GB DDR2, 320GB SATA2, 8800GTS Superclocked
« Reply #6 on: February 14, 2006, 04:40:06 PM »
Most coolers come with thermal goo.  That one does (at least retail it does).
If left at stock speed, the silent mode should be no problem.
meander
« Reply #7 on: February 14, 2006, 04:42:29 PM »
that sounds good.  that computer is starting to pis me off cuz it is loud. the sound comes from that card and psu. so this will help the matter
meander
« Reply #8 on: February 20, 2006, 11:29:56 PM »
i gotta let you know, that the vf700-cu is the greatest thing i have ever paid for it lowered teh noise on my compyboxen so much it is beautiful.  so beautiful i wrote a poem:  *ahem*
as i shed a single tear...
i shall not fear
for i can sleep tonight
my compyboxen is out of the darkness and into the light
lol that was bad i know.but yeah, i had to jerry rig a 2 way power splitter into a 3 way cuz i ran outa plugs, but it is awesome.  the ramsinks wouldnt fit on my card though, not a big deal however.
« Last Edit: February 20, 2006, 11:31:29 PM by meander »
Page created in 0.104 seconds with 34 queries.
