  • February 19, 2020, 09:30:15 AM
Author Topic: Looking for a Cheap PIC Burner and PIC Info  (Read 1726 times)
BillyBob
    • LANOHIO
« on: January 10, 2006, 11:20:46 AM »
Ok,
I think it's time I get out of the 80's and early 90's and start using PICs.
What I'm looking for is a low cost burner that will let me burn a pic with 32 outputs and a serial conection (RX TX for Rs 232), and a good place to learn about PICs. (website, books, etc.)
I've done a fair amount of assmbly programing and have worked with PAL chips, as well as you basic VB6 programing. But I have no  Idea where to start looking into pics.
Oh, I have used the Athena chips from Kronos Robotics (kinda like a PICAXe setup).
I know this is allot of Q's So I'm thanking you all in advance.
Billybob
(I'm a digital logic guy, NAND,NOR,OR,AND you know .....OLD School Electronics!  :lol:)
JusAzU tinkte Inet issafe
NEO-THE MATRIX
Re: Looking for a Cheap PIC Burner and PIC Info
« Reply #1 on: January 10, 2006, 12:44:17 PM »
The only "cheap" pic programmer I found is those DIY circuits on Elektor and Everyday Practical Electronics magazines, never found any ready made cheap ones.
*Celeron D 2.6GHz oced 3.33GHz*
*2x Corsair PC 400 DDR RAM 256MB*
*ABIT IC-7G MOBO*
*GeForce 6600*Internal Sound Mixer*
*SoundBlaster Audigy*SoundBlaster Pro*
meander
« Reply #2 on: January 10, 2006, 09:40:16 PM »
get this. it is only $12. it is the same one i have and i like it a lot. does everything i could hope for
i7 M 640, 8GB DDR3, 500GB SATA2, nVidia 330M
M=C2D E6850, 4GB DDR2, 320GB SATA2, 8800GTS Superclocked
BillyBob
    • LANOHIO
« Reply #3 on: January 12, 2006, 06:53:13 AM »
Thanks, That looks pretty good.
Now how do I learn how to program?
Billybob
meander
« Reply #4 on: January 12, 2006, 07:09:31 AM »
well, you can go the way most people and learn assembly, from here or you can get a free pic basic compiler and learn it here i personally used picbasic however it is not easily capable of the really advanced stuff. i would also suggest not using the 16f84 like the tutorials say, and using the 16f628 becasue it works pretty much the same and it is cheaper.
« Last Edit: January 12, 2006, 07:11:59 AM by meander »
