  • February 16, 2019, 10:56:21 AM
Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Useful Utilities  (Read 57200 times)
mile_high
Useful Utilities Updated 7/01/2003
« Reply #20 on: January 24, 2003, 11:24:34 AM »
http://www.google.com/  please look here before asking questions that you can easily find the answer to yourself...
http://www.onlineconversion.com/  "Convert just about anything to anything else. Over 5,000 units, and 30,000 conversions."
http://users.erols.com/chare/elec.htm  Processor Electrical Specifications
http://www.ping.be/satcp/  Your source for CD-R(W) Information
http://www.benchtest.com/index.html  All kinds of benchtest software and loads of other programs
http://www.pcguide.com/index.htm  "one of the Internet's premier sites for detailed PC reference information"
http://www.pchardware.ro/Download/index.php?catid=5  more good s/w downloads
« Reply #21 on: January 31, 2003, 02:38:16 PM »
http://www.spampal.org.uk/
SpamPal sits between your email program and your mailbox, checking your email as you retrieve it. Any email messages that SpamPal considers to be spam will be "tagged" with a special header; you simply configure your email client to filter anything with this header into a separate folder and your spam won't be mixed up with the rest of your email anymore.  It does this by checking each email against the DNSBL lists which are sites that have been reported to allow unsolicated email be relayed through them.
I have been using this program for about 6 months, and I get around 40-50 spam emails a day.  I have outlook setup to just trash all the spam emails, and about every other week I get an email that slips by.
The only downside to this program is that you realize how little real people like to send you email :(
DistantCube
    • http://www.csn-i.net
« Reply #22 on: February 03, 2003, 11:13:11 PM »
Blooz1
« Reply #23 on: February 07, 2003, 12:07:21 AM »
http://www.benchmarkhq.ru/english.html?/b_e.html
This site has links to almost 100 benchmarking programs....surf around!
Mick
« Reply #24 on: June 06, 2003, 05:19:36 AM »
Go nutz.
http://lists.gpick.com/index.html
<Edit> And for no reason while you're going nutz listen to these 4 songs and a Vid on one of them to increase your nutzingplationship (Alt Indie Brit Rock stuffingness. I should listen to music more often than just the few minutes that classical or whatevers on the radio when I awake):
http://capitolrecords.com/radiohead/player/      (I like Moon the best)
Sorry but my avatar commandeth and I must obey.
« Reply #25 on: June 30, 2003, 11:31:30 PM »
damaged
« Reply #26 on: July 01, 2003, 01:09:47 PM »
Click the image to download.
http://ho-stable.com/files/GTF_IE.Buttons.rar">http://ho-stable.com/images/ie.gif" border="0" alt="Click to download -2.59KB">
It's real simple, basically it puts a new button in IE that when pressed, sends you to forums.gideontech.com. Theres a readme file included, 2 icons, and 2 reg files. Although there is a readme file, some dumbass is gonna ignore it, then ask questions why it doesn't work, so I'm pasting it at the bottom of this post anyway.
x24 did the icons up for me, so pet him on the head, he also made them available (I only use the 32x32 versions) here:  http://mywebpages.comcast.net/x24/files/gt_icons2.rar
I used winrar to do mine, I assume x24 did as well, so you'll need to use winrar 3.* and higher, due to the new compression.
Quote from: README.txt
Copy the two icons into your windows (c:\winnt for nt/2k or c:\windows for 9x/xp) folder,
merge the CORRECT reg file - this means, don't do both. the one begining with 2k is for 2000, XP and NT, the one starting with 98 is for 98, and i assume ME and 95
open ie (or restart it)
if no new buttons are shown, right click next to the others and select customize
simply tell it to add the GTF button to your bar and hit close.
(edit:) It's only been tested in 98, 2k and xp, with IE 5+ and 6+ so if you have different, and it works or not, pm me and I'll see what i can do.
« Reply #27 on: July 01, 2003, 01:25:43 PM »
http://www.lavasoft.de/software/adaware/
Ad-Aware
great for removing adware, spyware, and that kind of crap
ScrapSilicon
    • http://www.heatware.com/eval.php4?id=3534
« Reply #28 on: July 07, 2003, 09:16:23 PM »
http://www.aida32.hu/aida32.php  ..:)
AIDA32 is a professional system information, diagnostics and benchmarking program running on Win32 platforms. It extracts details of all components of the PC. It can display information on the screen, print it, or save it to file in various formats like HTML, CSV or XML. For corporate users, AIDA32 offers command-line switches, network audit and audit statistics, remote system information and network management.
Starting with version 3.00, AIDA32 is released in 3 different variants. Please read the product matrix below to find out what are the advantages of each variants.
I use the personal version everywhere ..pretty much :)
http://www.aida32.hu/aida-download.php?bit=32
angrycrazymonty
    • http://www.cfztech.com
« Reply #29 on: July 27, 2003, 10:50:44 PM »
Do any of you know of a good program to use to overclock a Gforce FX 5600?
Pages: 1 2 [3] 4 5 6   Go Up
Page created in 0.039 seconds with 22 queries.
