  • August 16, 2022, 08:36:19 AM
Author Topic: Guide: Home Made Air Pencil Soldering Iron  (Read 27829 times)
All Your Base
Potential Rip
« Reply #10 on: March 07, 2006, 10:25:51 PM »
It seems someone liked this idea a bit too much. Not quite sure if this qualifies as a rip since it contains different content, but the similarities are there.
Engadget
Re: Guide: Home Made Air Pencil Soldering Iron
« Reply #11 on: March 08, 2006, 12:53:30 AM »
Personally, it only looks a couple degrees off a copy and paste.
« Reply #12 on: March 08, 2006, 09:47:22 AM »
At least they did give us and USBmicro credit of having done this before.
phantom
« Reply #13 on: July 26, 2010, 05:37:50 PM »
I'm having a hard time getting the air hot enough.  I'm using a TetraTec 30 liter per hour aquarium pump, 3' of 1/4" silicone tubing, and the RadioShack 64-2060 desoldering iron.  I'm using about 6 inches of 18 gauge copper speaker wire that I cleaned chemically to remove oxides, and have tried everything from stuffing the tip (and/or the chamber that the tip screws into) so full so that it slows down the airflow substantially, to putting in a small enough amount that the airflow is barely restricted.  I've also tried wrapping it around a nail to give it a coiled shape, then packing it in the chamber that the tip screws into.  The best I can do is get it to melt new solder off the roll from 1.5cm away if I hold it there for like 20 seconds.  Am trying to desolder a surface mount resistor on a board and can't get it to move for $#!+ :undec: I've connected the pump to a fan speed controller to slow it down, I've covered the area with rosin flux...nothing works.  Would really like to get this to work...any suggestions?
Page created in 5.31 seconds with 33 queries.
