  • November 12, 2019, 09:25:01 AM
Author Topic: fan filters  (Read 8093 times)
Mr Nubs
fan filters
« on: November 17, 2005, 05:21:09 PM »
hey i was thinking of buying a chieftec 601 for my new rig but i wanted to add fan filters, does anyone know if the fan clips on the case will allow me to use filters
thanks
~Link~
    • Project 365
Re: fan filters
« Reply #1 on: November 18, 2005, 09:02:18 AM »
Got any pictures of these fan clips?  I did a quick google, but I cant find any images.
Besides, if it doesn't fit: make it.  This is a modding forum after all.  :thumbsup:
Welcome to GTF.Don't drop the soap.
1 photo per day, for 1 year.  http://checkonetwo.ca
MegamanEXE
    • Cross Fusion
Re: fan filters
« Reply #2 on: November 18, 2005, 06:04:01 PM »
hmm i wonder what that small text says.....ah crap! i just dropped my soap!
* MegamanEXE bends over to pick it up
best fan filters for the money are the ones you make yourself. pantyhose works great
« Last Edit: November 18, 2005, 06:05:36 PM by MegamanEXE »
Whempys LAN Parties Administrator
Re: fan filters
« Reply #3 on: November 18, 2005, 08:03:22 PM »
I've been using dryer sheets for a while now and have been pretty pleased with them.  There may be better options out there, but I figure if it works for me I don't see a reason to change it now.  If someone has something better, I'm always looking for improvments.
Blooz1
Re: fan filters
« Reply #4 on: November 19, 2005, 11:10:09 AM »
If the fan holders you're referring to are the plastic kind where the fan "clips in", I doubt if you'd be able to use 'em.
Bear in mind that filters will need to be cleaned, therefore must be either removable or cleanable from the outside of the case.
Mr Nubs
Re: fan filters
« Reply #5 on: November 20, 2005, 02:13:59 AM »
thanks
bliq
Re: fan filters
« Reply #6 on: May 19, 2009, 12:55:28 PM »
search for "80mm fan filter" or whatever size you're looking for.
Page created in 2.8 seconds with 19 queries.
