  • June 03, 2020, 12:54:39 PM
Pages: 1 2 [3] 4 5   Go Down
Author Topic: USB battery  (Read 9018 times)
Re: USB battery
« Reply #20 on: October 15, 2005, 06:48:29 PM »
Parallel = same voltage, more current
Series = more voltage, same current
you want Parallel.
trials_modder
Re: USB battery
« Reply #21 on: October 15, 2005, 07:06:29 PM »
OK, I shall try testing the charger again, this time with two 9V batteries inside wired in parallel.
LOUD ANGRY NOISES
Re: USB battery
« Reply #22 on: October 15, 2005, 09:50:43 PM »
Have a gander at a datasheet for a typical 9V battery:
http://www.duracell.com/oem/Pdf/new/1604_US_Ultra.pdf
Pay special attention to the "discharge curves" section. There's not a linear relationship between load current and service hours. So it's not strictly correct to say that paralleling 2 batteries will double the run time.
The thing that is getting me is that 9V are about the worst possible choice for your application. You are forced to dissipate 4V* your load current in the regulator. That's just money you are throwing away. Make a 7.5V pack from 5 D cells if you want longer life. If you use rechargeables, they only have a 1.2V nominal voltage, so you'd need a 6-cell pack to get 7.2V.
9V batteries are specifically targeted to low load current applications (think transistor radio).
Re: USB battery
« Reply #23 on: October 15, 2005, 09:59:03 PM »
Agreed.  Everyone has a 7.2v rechargeable battery pack laying around somewhere, steal it from your little brother's remote control car for a trial if need be.
trials_modder
Re: USB battery
« Reply #24 on: October 17, 2005, 07:53:24 PM »
Yes, but then I have the problem of recharging the rechargable battery in the USB battery charger.
I think the USB charger is recharging the Zen micro, then drops to a certain current that triggers the Zen to think its plugged into an active computer and start its fancy glow-while-charging feature. Will two 9V at say 7V produce more current than a full power single 9V?
LOUD ANGRY NOISES
Re: USB battery
« Reply #25 on: October 17, 2005, 10:55:16 PM »
Batteries aren't magic eternal energy sources.  If you DONT go rechargable, you will have to buy new batteries every time you recharge your device.  Recharge it 4 or 5 times, and you've already spent far more for 9v batteries than you would have on a rechargable pack and charger.
trials_modder
Re: USB battery
« Reply #26 on: October 18, 2005, 10:00:16 AM »
Yes, but I don't know if the NiMH 9V rechargables i got are == powerful to a normail 9V. Maybe I'm charging it wrong, but it doesn't last nearly as long in other applications that the 9V alkaline.
p.s. this topic is on FIRE
LOUD ANGRY NOISES
Re: USB battery
« Reply #27 on: October 18, 2005, 10:12:45 AM »
A NiMH 9v cell (ie, the size you'd put in a smoke dectector) is going to have less capacity than an alkaline 9v cell of the same size.  This is why we are suggesting a 7.2v pack made from 6 x 1.2v NiMH AA size batteries, like one you would use on a remote control car.
trials_modder
Re: USB battery
« Reply #28 on: October 19, 2005, 10:20:07 AM »
I've had a remote control car before, but never a battery pack. How would I keep one of those charged?
LOUD ANGRY NOISES
Re: USB battery
« Reply #29 on: October 19, 2005, 10:47:45 AM »
They come with a wall charger.  You'd charge it before you wanted to use it.
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.085 seconds with 34 queries.
