  • June 19, 2019, 10:17:12 AM
Author Topic: Disapearing text  (Read 2847 times)
meander
Disapearing text
« on: August 02, 2005, 08:59:38 PM »
I was in pictures of china thread, and bout halfway down the post the pics started tweaking out, like the top 20 pixels of the pictures just repeated themselves over and over on the page until the post was over.  then the posts after, the text was missing. i thought it weas colored black so i tried to select, but there was really nothing there. when i deselected though, the text reapeared likew normal. i had to do that to the rest of the posts to read them.
i7 M 640, 8GB DDR3, 500GB SATA2, nVidia 330M
M=C2D E6850, 4GB DDR2, 320GB SATA2, 8800GTS Superclocked
Re: Disapearing text
« Reply #1 on: August 02, 2005, 09:11:03 PM »
Using Firefox?  Cause I had the same problem (and still do), but it works perfectly in IE.
ATFNegotiator
  • Legend - God - Hero?
« Reply #2 on: August 02, 2005, 09:59:04 PM »
ha im getting the same problem, im gonna go check it out in IE
« Reply #3 on: August 02, 2005, 10:26:47 PM »
It's a FF issue for some reason.
I wonder if breaking up the huge post will fix it. BalefireX?
chase!
  • The Internet!
« Reply #4 on: August 02, 2005, 11:36:15 PM »
YEAH BALE, WILL IT!?
« Reply #5 on: August 02, 2005, 11:39:21 PM »
Edited, should work now... tell me if it doesnt.
« Reply #6 on: August 03, 2005, 10:48:51 AM »
If that doesn't fix it. A way to re-darw the screen the way it should be is let go of the scroll bar and then scroll up a little bit then your fine for a little bit more.
Ran into the same issue the 1st time I logged in and looked at that thread.
Page created in 0.07 seconds with 20 queries.
