  • October 25, 2020, 10:24:02 PM
Author Topic: Review: Ultra X-Connect 500W Power Supply  (Read 3800 times)
« on: May 19, 2005, 02:04:17 PM »
The Ultra X-Connect is rated at a beefy 500W, which should more than enough for most modern day machines. That's actually not the selling point of this model. Instead of the typical wires, the design is made to incorporate modular wires. Use what you need, remove what you don't.
Captain_Picard
« Reply #1 on: May 19, 2005, 03:05:43 PM »
I have one fo these and it works pretty well. The cables are way too stiff to of any good. In fact, the SATA cable broke the black backing for the contacts on the HDD clean off inside the plug itself. THe HDD still works, but it is damaged. Also, the cables are way too long for a mid tower case (I'm using a Lian-Li PC65B) All the cables are bunched up at the top around the blow hole fan. If I had enough confidence in myself, I would shorten the cables myself.
Personally, I would rate the PSU a little lower. More like 7/10.
Later
« Reply #2 on: May 19, 2005, 03:15:23 PM »
It fit alright in my case, so I didn't dock any points off for that. The biggest peeve was the loose SATA connect.
MadProphet
« Reply #3 on: May 19, 2005, 03:48:29 PM »
My fan crapped out after 3 weeks on my Ultra and I was set for the PSU crapping out shortly after but I replaced the fan and it is still goign strong and stable 5 months later
« Reply #4 on: May 20, 2005, 05:57:18 AM »
Dual fan with a big arsed grill...  :wtf:
No Tact
« Reply #5 on: May 20, 2005, 08:00:52 PM »
All I have to say is go here and see the RMA nightmare.
Link to my Ultra Experience
My experience and my posting it on 20+ tech sites changed theier RMA policy. Ids it better now? Take the risk if you dare.
Alric_the_mad
« Reply #6 on: May 21, 2005, 01:00:26 AM »
no tact: your username is quite fitting.
No Tact
« Reply #7 on: May 21, 2005, 07:12:54 PM »
Quote from: Alric_the_mad
I had not noticed.
Thanks for pointing that out for me. :idiot:  :lol:
« Reply #8 on: May 23, 2005, 10:08:17 AM »
ED you need to get a case that has the HD mounted side ways (Power / Cable Rails are agains the side of the case). The Plugs on them would require the same change you did for the sata for them to fit. It would be a reason to make it down.
I hope dont have any problems with it. I know a few friend that have gotten it and 1 has replaced his complete system because the PSU failed (Bellowing smoke after about 3 months).
The other one replaced it after a month because the able problem listed above.
« Reply #9 on: May 23, 2005, 10:16:18 AM »
Yes, full tower case is on the way actually. I've been procrastinating...
Page created in 0.315 seconds with 48 queries.
