  • July 23, 2019, 01:29:20 PM
Pages: 1 2 [3]   Go Down
Author Topic: Bass activated LED's  (Read 7623 times)
trials_modder
Re: Bass activated LED's
« Reply #20 on: February 14, 2006, 05:26:04 PM »
K just to get this straight:
5V positive hooks up at pin 8
5v negative hooks up at pin 4
Input A positive hooks up at pin 3
Input A negative hooks up at pin ?
Input B positive hooks up at pin 5
Input B negative hooks up at pin ?
Output A positive hooks up at pins 1+2 combined.
Output A negative hooks up at pins?
Output B positive hooks up at pins 6+7 combined.
Output B negative hooks up at pins?
LOUD ANGRY NOISES
« Reply #21 on: February 14, 2006, 07:55:22 PM »
The input grounds are all connected together and connected to GND.  The output grounds are all connected together and connected to GND.  Remember that the inputs have to go through the RC network and the ouput of the RC network goes to the input of the opamp.
trials_modder
« Reply #22 on: February 15, 2006, 02:12:28 PM »
Are these chips you talk about the "UA741" and the "MC1458"?
LOUD ANGRY NOISES
« Reply #23 on: February 15, 2006, 02:53:54 PM »
Yeah, well the uA and MC just denote different temperature ranges and whatnot.  As long as you get a 741 or a 1458 of some sort, you should be fine.
Pages: 1 2 [3]   Go Up
Page created in 3.909 seconds with 20 queries.
