  • August 13, 2022, 07:32:20 PM
Author Topic: Review: Corsair USB2.0 Flash Voyager 512MB  (Read 3704 times)
« on: May 06, 2005, 07:09:02 PM »
The Flash Voyager provides fast access to 512MB of portable storage. Not only is it fast, it also comes equipped with a rubber shell to protect all your valuable data.
« Reply #1 on: May 06, 2005, 08:16:51 PM »
Out of curiosity, does this drive have a very slow speed (and i mean a VERY slow speed) when dealing with a large number of small files, for example 100 word documents.
My cheap sandisk drive and verbatim 512MB drive both had this issue but my CF and SD cards dont have this issue.
acronym
« Reply #2 on: May 08, 2005, 03:28:15 PM »
the most important test (I think) in using a flash drive is whether it draws too much power to be used in an un-powered hub (like a keyboard).  I've found few drives that'll work well without having to get behind the computer to plug the thing in.
« Reply #3 on: May 08, 2005, 03:38:52 PM »
Quote from: acronym
yea but people should know NOT to use unpowered hubs. The USB specification specifically states up to 500mA per port, therefore a device is allowed to take up to 500mA.
« Reply #4 on: May 08, 2005, 04:12:21 PM »
Quote from: nemattoad
Not that I know of. I'll try a larger amount and report back.
« Reply #5 on: May 08, 2005, 04:57:36 PM »
Just copied 194 misc. files in about 20 seconds, no problems.
« Reply #6 on: May 08, 2005, 06:00:45 PM »
awesome, I will keep this in mind if I see a good deal for it in Canada.
BotchedLobotomy
« Reply #7 on: June 18, 2005, 03:52:21 PM »
I bought one based on this review. it owns.
Page created in 0.124 seconds with 62 queries.
