  • June 18, 2019, 03:45:11 PM
Author Topic: 120mm Much Quieter than 92mm?  (Read 2397 times)
KJSatz
« on: May 03, 2005, 08:55:45 PM »
So in the center of my left side panel, I have a 92mm fan (Antec) which is vented to blow in onto my HSF.  I was messing around with a ruler and found that a 120mm fanhole would cover up the 92mm fanhole, screws and all.  So that got me thinking.  And I'm thinking about buying this 120mm green LED fan to match how my case is green and whatnot.  Plus the green LED is cheaper than non-LED.
120mm - http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=370518
Osse77
« Reply #1 on: May 03, 2005, 09:03:28 PM »
Yes, 120mm fans are slower but push more air than a 92mm
bruno8747
« Reply #2 on: May 03, 2005, 09:08:43 PM »
go with the 120mm its gonna be more quiet and push more air.
KJSatz
« Reply #3 on: May 03, 2005, 09:56:57 PM »
Sweet action, needed to get my dremmel wherring anyway.  I still need to finish my bezel too...poor naked case *looks at power switch and DVD drive hanging out, bare steel* siiiiiiigh.
« Reply #4 on: May 05, 2005, 04:57:56 PM »
Get a 120x38 instead of a 120x25. ;)
glassx
« Reply #5 on: May 05, 2005, 07:50:04 PM »
A good 92mm fan will be quieter than a sh*tty 120mm, and still move the same amount of air.
(example: Panaflow vs Sunon)
KJSatz
« Reply #6 on: May 05, 2005, 07:52:13 PM »
Yeah but this is an Antec and a Thermaltake...no sorries about sh*tty fans between them.  The only x38mm fans include both Panaflow and Sunon...which of those is the "sh*tty" one?
glassx
« Reply #7 on: May 05, 2005, 07:57:31 PM »
Sunon. Duh :P
Also, Tt doesn't make all that good fans, they aren't ball bearing fans, or atleast the one on the silent boost. (which i assume is a "good" Tt fan...)
bruno8747
« Reply #8 on: May 05, 2005, 08:20:35 PM »
Quote from: KJSatz
Go with the panaflo that has the fluid bearing or a cooler master rifle bearing fan.  Or just a 120mm sleeve bearing.  Ball bearings will last longer but tend to be on the noisy side.
AlienBlood
    • http://www.battlestar.us
« Reply #9 on: May 05, 2005, 10:24:07 PM »
Panaflo all the way.
Page created in 0.034 seconds with 19 queries.
