  • April 01, 2020, 10:33:55 AM
Author Topic: (2) 8 gauge = (1) 4 gauge?  (Read 3732 times)
bruno8747
« Reply #10 on: April 12, 2005, 12:27:55 AM »
Quote from: Excess3
1400 amps... yah.
Good call on going with the 2 gauge.
Oops I mean "about the amplifiers"
« Reply #11 on: April 12, 2005, 01:25:18 AM »
1300 watts at 12 volts is 109 amps.  You'll need 1 gauge at least.
bruno8747
« Reply #12 on: April 12, 2005, 02:05:48 PM »
Quote from: viridius
Do I really need 1 gauge, because the amplifier says it needs 4 gauge.  But I dunno....I am thinking 1 gauge might be a pain to run through the car.
« Reply #13 on: April 12, 2005, 02:09:06 PM »
I doubt you'll have sustained 1300 watt comsumption, so if the manufacturer says 4 gauge, go 4 gauge.
« Reply #14 on: April 12, 2005, 03:07:31 PM »
I only ran 6AWG when I installed a subpanel in my barn. I'd expect 4AWG to be adequate for a car stereo.
Matt_T_Bratt
« Reply #15 on: April 12, 2005, 03:45:01 PM »
If you have to buy the wire anyway, might as well run 2 awg.  and it's not so much a pain to run (it is so you can't see a lump running under the carpet), but it's a REAL pain in the ass to run through the firewall.  With 8 or less you can usually run through an existing grommet, with that large you need to drill a hole and install a grommet (DO install a grommett) and be sure and fuse that wire.  Shorting out a wire that can carry 100+ amps is bad news.
Page created in 0.066 seconds with 61 queries.
