  • April 02, 2020, 05:07:04 AM
Author Topic: (2) 8 gauge = (1) 4 gauge?  (Read 3733 times)
bruno8747
« on: April 11, 2005, 05:51:34 PM »
Quick question: I want to hook up some car audio equipment and I need some info on wire sizes. I want to run 4 gauge wire in the car but all I have is 8 gauge. Now what I want to know is if I run 2 pieces of 4 gauge in parallel from the battery to the amps what gauge wire would I get? Would I get 6 gauge or 4 gauge?
Shiz
« Reply #1 on: April 11, 2005, 06:14:03 PM »
i'm confused with your topic and your post. what i think you are saying is that if you run 2 4 gague lines will it equal 8 gague total? Correct me if i am wrong.
edit: sh*t i feel so dumb. i forgot the higher the gauge, the smaller the wire. lo siento!!!
Chris
« Reply #2 on: April 11, 2005, 06:24:52 PM »
He's trying to ask if he puts 2 8 gauge wires together will it equal a 4 gauge and i believe the answer is yes.
Work
Home
bruno8747
« Reply #3 on: April 11, 2005, 07:26:20 PM »
Quote from: Chris
Thats exactaly what I am trying to say.
Syberz
« Reply #4 on: April 11, 2005, 07:55:15 PM »
Although I believe 2x8gauge = 4gauge I don't think it'd be a good idea to do that. I'd invest the 5$ to get some 4 gauge.
ATFNegotiator
  • Legend - God - Hero?
« Reply #5 on: April 11, 2005, 08:11:55 PM »
errr I dont think that'll work, but im not the expert on that. Smaller the gauges, the more it'll be able to burn up, but if you use two wires... well i dunno never thought about it.
« Reply #6 on: April 11, 2005, 08:26:24 PM »
Just look at the wire size table.  4 gauge wire is rated for 55 amps continuous, 8 gauge for 22.  2 8 gauge wires would pass 44 amps, so you'd be 11 amps short.  Find your power draw first and work back from there.
neostar63
« Reply #7 on: April 11, 2005, 10:30:08 PM »
Dont shortchange the wiring in your system. How many watts you will be pushing with the amp is going to determine the gauge of your wiring.
bruno8747
« Reply #8 on: April 11, 2005, 11:39:19 PM »
I am gonna scrap the 8 gauge plan and get some 2 gauge now.  About the amps...plan on pushing atleast 1400.  I am gonna get an infinity 1210 amp that does 1300 watts rms and probably another infinity 4 channel.  And yes I am mostly gonna need an upgraded altenator (and some new windows :) )
Excess3
« Reply #9 on: April 12, 2005, 12:24:08 AM »
1400 amps... yah.
Good call on going with the 2 gauge.
Page created in 0.054 seconds with 48 queries.
