  • July 06, 2020, 12:39:48 AM
Pages: 1 2 [3]   Go Down
Author Topic: what is the best  (Read 3419 times)
Excess3
what is the best
« Reply #20 on: March 29, 2005, 02:30:27 PM »
the best?
Metcal.  Hands down.
If you can afford a Metcal station you are soldering like the pros.
By flat LEDs do you mean surface mount LEDs?  Get a tweezer adapter.
Metcals are awesome.  Tips heat up in seconds (it uses RF!), makes it great when doing complex work.  Its real easy to swap out those tips.  I love metcal stuff.
Seriously.  If you are really going to be doing solder work (bench work, not on the fly under the dash on site work) Metcal is hands down the best frigging soldering station out there.
Pages: 1 2 [3]   Go Up
Page created in 0.053 seconds with 33 queries.
