  • January 20, 2022, 12:20:08 AM
Author Topic: Guide: merliniplexi 2.0 Guide: Part I  (Read 2909 times)
« on: March 06, 2005, 07:33:56 PM »
This is the first part of a multipart guide dealing with the construction of the merliniplexi 2.0 Plexiglas case.  In this guide, we will be discussing stand-offs and how to glue the outer panels of the case.
nOObee
« Reply #1 on: March 06, 2005, 08:19:32 PM »
way to go, bubba.   a plexiglass case how-to is long overdue.   (i enjoyed the disclaimer, for obvious reasons)
i am not seeing the pics yet.  i am wondering if i need to grab a plug-in for firefox?
questions--
-what method did you use to laminate the two panels?   i would think that capilary action might not do the job.   i understand that there is a dipping method for this.
-what method did you use to hold the panels at 90 degrees while bonding them?  did you just use a square, or did you build a gluing jig?
« Reply #2 on: March 07, 2005, 12:56:31 AM »
Quote from: nOObee
You would be suprised how well capilary action works.  It sucks up the cement like a sponge.
I used a square for the rear and side panels.
bruno8747
« Reply #3 on: March 07, 2005, 01:30:30 AM »
The front of the case:  how did you get the color like that.  Is it dark plexi or tints?
« Reply #4 on: March 08, 2005, 02:17:43 AM »
It's what is called bronzed plexi.  Its tinted all the way through rather than on the outside like you would see on a car window.
Page created in 0.082 seconds with 47 queries.
