  • February 19, 2020, 06:12:41 AM
Author Topic: Alkaline vs "heavy duty" batteries  (Read 3226 times)
Bill030
« on: December 07, 2004, 10:36:34 PM »
I've got a project I'm working on that requires the use of AA batteries. I'm not looking at anything really expencive but from what I understand alkaline batteries are much better than cheap heavy duty batteries even if they cost a little more. They perform better in extreme temperatures and last longer life is what I'm told. I'm also aware that heavy duty batteries have a bad shelf life while alkaline last much longer. Can anyone clarify the differences for me?
« Reply #1 on: December 07, 2004, 10:50:17 PM »
According to Digikey, Panasonic's carbon-zinc LR6 batteries will take 110 hours to discharge to 0.9 volts with a continuous load of 100 ohms.  Carbon zinc cells cost 33 cents each individually or 22 cents each in a package of 60.  The alkaline batteries will take 170 hours and cost 54 cents each or 36 cents each in a package of 40.  Purchased individually, the alkaline batteries will cost 0.018 more cents per hour of life, but this difference drops to 0.012 cents per hour in bulk.  Leakage is low for both types and if the batteries are used within a few years of their manufacture date, there should not be any significant deterioration in performance.
AzNPrideBoy
« Reply #2 on: December 08, 2004, 02:46:41 AM »
I don't think you can get a much better explaination than that!
« Reply #3 on: December 08, 2004, 12:47:51 PM »
One reason for alkaline's popularity is the they "hold up" closer to the rated voltage for longer over the useful life. This tends to be why electronics makers specify alkaline cells. In a flashlight, it's not so important since a half-bright light is better than nothing. Half voltage to a CD player wouldn't get you much at all though. Carbon-zinc is cheaper for the equivalent amp-hours (according to studies I've seen).  Spend the extra (it's not a lot) for alkaline if you need the characteristics of them. Sometimes internal resistance matters.  If you're trying to do pulses of high current (like driving a hot LED in a flashlight mod) the low internal resistance of alkalines is desirable.
There's good info on the duracell site:
http://www.duracell.com/oem/Pdf/others/ATB-5.pdf
http://www.duracell.com/oem/productdata/default.asp <- more than you want to know
geeksquad
« Reply #4 on: December 10, 2004, 08:37:16 PM »
well, i do agree that alkaline is the better battery. for example, alkaline in digital cameras will allow for say 100 photos while heavy duty stuff will only go a few rounds. just my experience
geek squad
Recycle Ben
« Reply #5 on: December 14, 2004, 01:36:42 PM »
Why not go with rechargeable NiMH AA batteries.  They are used in digital cameras.  I have seen them at Bestbuy and on-line at resonalble prices.  I have seen 2000mAH sized AA's.  A charger would be requried.
If your battery usage is going to be high, NiMH might be a cost effective way to go.
______________________________________________
Stupidity will win in the end because the supply is endless.
BiGReD
« Reply #6 on: December 14, 2004, 07:16:00 PM »
I exclusively use NiMH Rechargeable batteries.  Last as long as Alkalines if you get good ones (2000+ mAH), and you buy them once and they last a looooong time.  Beats shelling out a few dollars every time you run out of power.
crazyea6
« Reply #7 on: December 27, 2004, 05:50:32 PM »
Defintiely stay away from the Heavy Duty batteries. I think it is just a name companies give batteries so people think they are getting a good deal. I spent a small fortune on those Heavy Duty batteries and finally I came to my senses and started using alkaline. As for rechareables, I am always on the go and I dont have to worry about charging them.
« Reply #8 on: December 27, 2004, 06:17:30 PM »
Quote from: BiGReD
same here, i have a fleet of at least 10 NiMh batteries I have accumulated over the years that came with devices or I bought. I also have 1 NiMh 4-battery charger that is quite reliable and fast.
I use NiMh batteries in all my often used devices like my MX700, digital camera, and LED flashlight. For things that use VERY little power or are not used often, i use regular batteries from costco. Things like remote controls, logitech elite wireless keyboard (using regular crappy batteries for over 4 months without a change!).
goawaystalkers
  • Hello
    • J3hijinks
« Reply #9 on: December 28, 2004, 05:34:36 PM »
Ditto
Page created in 0.064 seconds with 47 queries.
