  • October 22, 2020, 09:39:44 PM
Pages: 1 2 [3]   Go Down
Author Topic: little LED problem  (Read 3263 times)
To-mod-or-not-to-mod
little LED problem
« Reply #20 on: December 05, 2004, 03:35:47 PM »
Quote from: Firespark
Quote from: To-mod-or-not-to-mod
That works? I might have to try that!
like viridius said, it isnt the best power supply, and it does fluctuate, but i find that with low end led's, they dont tend to care. plus, with a grab bag, if you do fry one, so what? it cost you like a penny.
case in point ive been fooling around with a grab bag of led's from radioshack  for maybe a year or 2, and i have yet to exhaust the supply.
Ill have to start trying that then... Thanks!
little LED problem
« Reply #21 on: December 05, 2004, 07:59:51 PM »
A shorting LED can trip the overcurrent protection on a computer's PSU and can damage other components (eg: hard drive controller boards).  Batteries are, to some extent, fine since you're not going to put other expensive components in danger, but I would not recommend blindly substituting LEDs into your computer.
Pages: 1 2 [3]   Go Up
Page created in 0.088 seconds with 61 queries.
